주요 콘텐츠로 건너뛰기
닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
702 질문 전체 보기
Not turning on after screen replacement
I'm replacing a LCD on a Nintendo Switch that was working fine before I attempted the repair but had some spots on the backlight. After trying the new LCD, I was noticing that the backlight turned on for a second but then everything would shut off. I double checked my connections, pushed the LCD connector in as far as it would go but still got the same result. I decided to try the original LCD but got the same exact result as the replacement. Any ideas or suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개:
I'm now noticing something strange. If I have only the backlight ribbon cable connected (leaving the LCD cable disconnected), the Switch turns on. But as soon as the LCD cable is connected, the Switch won't do anything. Could there be a short somehow?
Same thing happened to me currently! I know this might be late but did you ever find an answer?
I have the same issue. I replaced the lcd connector and now the console doesn't work when the lcd is plugged in... It's really a crappy situation, since the guy who owns the switch is now threatening me.
댓글 달기
답변 3개
Maybe it’s a bad LCD, might try to get a replacement maybe
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I could try that. But wouldn't the original still work?
댓글 달기
Well bummer. 4 years after this original question was posted and no clear answer. Hoping this comment will bump this in the algorithm somehow so it can be answered!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I bought replacement parts for my Nintendo switch then disconnected everything then assembled it back together and tried to turn it on and when I did the screen won't show any signs of power, just stayed blank so then I charged it even for a long time and nothing changed. I looked everywhere online and looked at video tutorials and read many articles for my switch and it just don't work. Since my attempt to repair it was unsuccessful then nobody can't repair my switch. It's best to get a replacement switch and cash is limited to me for some time because I have so much things to focus on doing before getting a new one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tech Gurus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 1,279
