Vizio power button issues plus
Model: Vizio E55u-D2
Serial: LWZQTYDS
Seems like the buttons on the side of tv either don’t work or at best intermittent and the IR sensor doesn’t seem to receive anything from the remote, it’s transmitting I checked it. Also there is no power light ever, I even turned it “always on” but there is never a power light.
Originally thought it was a power issue but those all feed into the main board so now thinking it’s a main board issue.
Ideas?
Thanks
Eric
좋은 질문 입니까?
댓글 2개
Yep it definitely is the sensor board causing at least part of the issue. As I looked more closely it looks like it was fried. Looks like the cable ends had some black marks as well so I have ordered a replacement sensor and cable.
So that explains the remote and no power light issue but not the power buttons on the side of the tv does it?
So I disconnected the sensor cable and sensor to get it out of the loop.
So Talking about side of the tv.
Power button and vol + don't seem to do anything.
Vol - button seems to turn it off and I can’t get it back on except to unplug it and plug it back in, Even then it takes a few iterations. There seems to be no rhyme or reason of when the tv come back on.
Input button doesn’t do anything.
I tested the standby power volts and it reads 5v with the main board connected and when not. The cable for the side power and sensor plug in to the main board fairly close. Could the damage reached the board from the sensor? I can not see any visible damage.
Thanks
eric_sfo 의
Hi Eric_sfo - I also have a Vizio with the same problem (power button on TV and remote don't work). Not sure if this is a IR sensor problem or motherboard problem. What did you learn from your situation? Mine is m471i-a2.
Hans Klinger 의
