Released in the USA on July 28th 2017, the Nintento 2DS XL is a handheld gaming console that is a streamlined version of the 3DS XL.
32 질문 전체 보기
Why won’t my Nintendo 2DS XL turn on?
Recently, my 2ds xl will not turn on no matter what I do! Just a Week ago it was working perfectly now it won’t turn on? If anyone can give me some advice that pI duo be greatly appreciated :) thank you.(also even if I charge it no lights flash it just won’t turn on
점수 0
코멘트 추가
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
@hobi_j check your charger to make sure that it is working. After that check the charging port to make sure that it works and check/replace your battery. That way you have a known well starting point for further troubleshooting. If all of those parts are functioning you will have to disassemble your 2ds xl and check for any obvious damaged components on its motherboard. Post some good pictures of that with your question so that we can see what you see. Adding images to an existing question and here is the teardown Nintendo 2DS XL Teardown
iFixit 이미지
안내서
Difficulty:
아주 쉬움
2 - 5 minutes
Nintendo 2DS XL 이미지
안내서
Difficulty:
보통
점수 0
댓글:
Uh yeah ok. I am currently not at home where my 2ds xl is but once I arrive I will be able to show some photos of it. Also I will be getting a new cable to see if that works since I have been using the same cable I
Got from my dsi in 2012. (I think I may have lost my 2ds xl charger I don’t know)
의 답변
코멘트 추가
Add your answer
Joel Serrano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 22
