phone has been damaged due to spill of tea and destroyes the screen
i have destroyed my phone completely has i spilled tea on my redmi note4 and the sceern and touch has been destroyed totally what should i do
좋은 질문 입니까?
좋은 질문 입니까?
@starlord119 The very first thing you want to do is to not try to restart/sync the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using this video. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning 3/4 of the board. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for an Apple 3G iPhone, all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken missing. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. It is entirely possible that you may need a new display assembly as well but for as long as you have not done anything to repair the damage it would only be a guess. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 3
30일 전: 21
전체 시간: 319
