주요 콘텐츠로 건너뛰기
A1708 / EMC 3071—2016년 11월 출시, 이 MacBook Pro 13”는 OLED Touch Bar를 소개합니다. 듀얼-코어 "Skylake" Intel Core i5 CPU 및 Thunderbolt 3 포트 4 개 포함.
237 질문 전체 보기
When the flexgate is repair apple install the new 2mm longer cable?
I want to know if when apple repair the flexgate on the macbooks they use a new display cable with the same length as the one already damage or they opt for the 2mm longer they start to put in the newer models?
I don’t check it myself because I really does not know much about operating a computer and don’t want to damage anything.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Apple won’t replace the display cable (technically the whole display assembly) proactively! Until it fails you’ll to wait,
Here is the current 13” MacBook Pro Display Backlight Service Program
Sorry ;-{
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
My bad, I forgot to mention that my 2016 MacBook Pro was already fixed from this exact problem.
But I want to know if the fix is for the same display that have the short cable or the display in the new models that have a 2mm longer cable.
The reason is because if they put the same display that came with that model (one with short cables) I suspect that the fix will be for some 2 or 3 years more because it will happens the same thing. In the other hand, if they change it the problem replacing with the new displays (with the longer cables) it may extend the live or already fix the problem. That why I’m curious.
If some further explanation is needed just ask and also thanks for respond to my incomplete question.
Well, that changes things a bit. I have no way of knowing which assembly they put in. Depending on the timing you could have gotten the original spare or the updated spare.
Maybe your paperwork can give you a clue on the parts info.
댓글 달기
귀하의 답변을 추가하세요
Eric 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 436
