주요 콘텐츠로 건너뛰기
Apple 워치 시리즈 2 는 2016년 9월 7일에 발표되었고 2016년 9월 16일에 출시되었습니다.
132 질문 전체 보기
After disassembling another problem screen
Good afternoon.
I acquired an Apple Watch 2, which has the screen with a diagonal break / cut. When I tried the touch did not work well (not much could be done, as it was not necessary), the screen showed image and when pressing the buttons Siri speaks extremely fast and weird. I thought that the failure of Siri to speak extremely quickly could be because the touch was broken because of the blow that took the screen glass and I proposed to disassemble the screen and connect all the cables of this, except the central , which comes from the touch glass, to check the reaction of the voice heard when you enter the menu, etc.
To my surprise, when I start the Watch, the screen is seen correctly until the apple, after about a minute of loading, the apple disappears and the menu is not shown. If I press any button you can hear Siri speaking just as quickly and strangely but you can't see anything on the screen.
Could you tell me why you can't see anything after the apple? And another important detail, why does Siri speak so weird?
I ask these questions because I would not like to acquire a screen and that these errors did not disappear.
Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hello,
Sometimes these watches are extremely delicate that even a screen damage can be a lot of trouble since everything is inside of the device including the speakers. I would suggest you to replace the screen if possible, if not most likely that watch will need to be replace. We all know that Apple products now a days after the main guy died, they are not as good as they used to be.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for your answer Daniel, although I am looking for someone who has had a similar case. Thank you.
댓글 달기
귀하의 답변을 추가하세요
Francis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 88
