Will NOT boot. iTunes sees device ok.
3G stuck with only Apple logo. Restored to 4.2.1 with iTunes;shows serial#, etc. Thinks it has music and lists titles but doesn't show anything on screen except logo. Tried redsnow,tinyumbrella,etc. and again thinks it did something but it won't boot to a desktop display; just an Apple, Pineapple or Snowflake. I checked cables going to screen (seemed tight).
What to try next? (Help!!!!!) please.
좋은 질문 입니까?
댓글 7개
tried tinyumbrella or iReb to get out of boot loop?
pollytintop 의
Your screen shows a White Apple, and at the same time iTunes recoginizes it? Will screen show White Apple when unplugged or does iPhone shut OFF? What Error Codes is iTunes giving you?
Brad 의
Thanks for the responses! I tried TinyUmbrella but not IReb. There are no error codes from iTunes (it thinks everything is fine). The logo stays on whether plugged or unplugged. The restore process proceeds correctly and when it's done iTunes believes it's functioning; but all I'm left with is the logo and no boot up. I'm thinking this might be a true hardware issue?
vabeach50 의
I left it on ac wall charge for 5 hours. Same thing. It just won't boot.
Thanks.
vabeach50 의
try taking the motherboard out for a few hours, check your battery output with a multimeter, clean the dock which connects to USB. Then reassemble
pollytintop 의
댓글 2개 더보기
