메인 컨텐츠로 가기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
1379 질문 전체 보기
Flexes Don't Line Up With Logic Board Sockets
Hey there, I just got a housing replacement with the flexes and parts already installed. I have noticed that the dock connector flex does not line up with the dock connector socket on the logic board (it is just 2-3 millimeters off but I cannot connect it at all even if I move the flex around) and the upper cable connector is just slightly to the right so I cannot connect that either. Does anybody have a solution? It would be hugely appreciated as I need to repair this phone ASAP.
Sorry for tagging you @refectio but I thought that you’d know a solution as you are a very knowledgable and active member here.
Thanks!
답변함! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
코멘트 추가
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
6개의 답변
선택된 솔루션
Thanks a lot for all your contributions, they all have helped me find the answer. There were many issues:
1) The flex cable was a cheap low quality one so it would barely fit on the board without damaging it.
2) The flex cable was not aligned properly.
Solution: I decided to replace the charging port with the OEM one and my problem was solved!
Thanks so much everybody.
이 답글이 도움이 되었나요?
점수 0
코멘트 추가
가장 유용한 답변
Compare the flex on your new casing with the old one. Oftentimes new parts don’t have the flex cables folded, and you need to do it yourself to get everything to fit.
이 답글이 도움이 되었나요?
점수 1
댓글:
Hey, I have folded them but they still dont line up! I have moved them around and folded them but am having no luck. If I move it too much then the flash moves out of place.
의 답변
코멘트 추가
Hi @rafay99
I have had this issue many times with the iPhone 7 and 8 charging port replacements. The best way to ensure the connector alignment is to connect the cable to the logic board, wrap it around underneath the board and tape it against the bottom side. Once you’ve done this, you can put the logic board into the iPhone frame and stick the charging port down where it needs to be to preserve the alignment. After that, you can continue to install the charging port as normal.
Best of luck!
이 답글이 도움이 되었나요?
점수 1
댓글:
Hey, I tried this but as soon as I put the logic board into position the charging port flex disconnects.
의 답변
I'm thinking that you have a bad connector at this point then. Hopefully its only the charging port flex that's bad and a higher quality replacement charging port should install a lot easier.
의 답변
코멘트 추가
the 7 has 2 white dots on the shell that should line up with 2 holes in the charge port flex (near the connector end), this is so they line up, if you having problems getting them lined up then unstick the charge port flex off the shell and line the holes up with the dots, you may need to remove the loud speaker inorder to adjust the flex correctly.
if you have messed about with the connector too much you may need another charge port flex or it will keep popping off.
이 답글이 도움이 되었나요?
점수 1
코멘트 추가
This is a common problem with the 7 dock flex. I have just finished replacing one and had the same problem. I ended up connecting the dock flex first than putting the board in and working backwards. Hopefully there is not too much adhesive on yours so you can do the same.
이 답글이 도움이 되었나요?
점수 1
코멘트 추가
You must have the incorrect dock charging port There is different once for different phones
For exanple an iPhone 6 dock charging connector will not fit an iPhone 7
이 답글이 도움이 되었나요?
점수 0
댓글:
No, that is definitely not the case, the charging port, loud speaker and taptic engine all came from a working functional iPhone 7 that was iCloud Locked.
의 답변
코멘트 추가
답변 추가
Rafay Siddiqui 이(가) 영원히 고마워 할 것입니다.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 49
