주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Mac mini 제품군은 2005년 1월에 처음 소개되었습니다.
1400 질문 전체 보기
move data
I purchased a replacement HD for the one that died in my mac mini. I was using time machine to back up to an external hard drive. Once i get the new hard drive installed into the mac mini how do i go about getting the data from my backup to my new unformatted 320 gb hard drive?
Thanks!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 3개
가장 유용한 답변
When you first power on, and the setup runs, it should ask you if you want to take the data from a wireless time machine.
If you do not get the setup it may be in System Preferences>Time Machine
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Here's a TUAW article on the subject: http://www.tuaw.com/2008/01/27/restoring...
Basically, when you're installing OS X on the new drive, select the option to restore the computer from a Time Machine backup. The TUAW article has the details on where to find the options you need.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
After following one of the hard drive replacement guides, you'll need to install an operating system. Depending on the age of your computer, you can do this by holding command ("⌘") + "R". If you are unfamiliar with installing an operating system, I recommend following this guide.
Once your operating system is installed, you should be greeted with a setup screen. One of the pages will prompt you to restore your backup. Following the steps, and you should be back up in no time!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
gayle 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 939
