주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
313 질문 전체 보기
Blank screen, no boot after hard-drive wipe?
I will try to provide as much detail as possible please ask if you need additional:
Was running OS High Sierra on early 2014 MacBook air
The computer was working 100% fine before I formatted the hard-drive
It has never experienced falls, hits, or water damage
Battery and charger components are fine and working accordingly
Originally the screen displayed the folder with a “?” but I did not have a bootable USB set up yet so I shut it down
After restarting the mac the screen is just a blank blueish-purpleish color
off screen for reference ''
with:
  • Keyboard backlight - Off
  • Display backlight - On
  • Apple logo on back of Mac - On
  • Fan spinning at normal speed
  • Does not get overly hot if left on
  • No peripherals connected
Things I’ve already tried:
  • Every possible key combination during and before the boot phase
  • (The only keys that do anything at all are the power button held down and the SMC reset, which fixes nothing)
  • Booting without battery connected and on charger
  • Booting without SSD connected
Any advice would be appreciated, the nearest apple store is over 2 hours from me and if it is hardware related I cannot afford to replace it at the moment.
Don’t think this will help but will include anyway:
Screw in SSD has now been put back btw
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Let’s disconnect the MagSafe & battery. Press the power button a good minute. Putting the system on its side with the MagSafe up, Now plug in the MagSafe and press the Option (⌥) key are you getting to the Startup Manager screen?
Reference: Mac startup key combinations
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
@danj No luck, I also just tried with the battery plugged in just in case.
Ouch! Somehow the logic board got damaged.
@danj I thought the issue may be more serious but do you think it's a bit strange that the logic board would go the same time I wiped my SSD? This all happened within the hours
Did you unplug the battery before taking the SSD out?
댓글 달기
귀하의 답변을 추가하세요
Evan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 124
