주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
298 질문 전체 보기
upper case for antiglare MacBook Pro 15 Unibody Mid 2009?
I just saw in the notes that the upper case for the macbook pro 15 is only for the regular glossy screen version.
Where can I get an upper case and instructions for changing it on an antiglare screen equipped macbook pro 15inch - unibody mid 2009?
Thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
The part number for the Anti-Glare is 661-5295. Just google that number for parts. The only difference between the screens is the outer glass. So installation instructions are the same.
Use this guide if you're replacing the whole thing: MacBook Pro 15" Unibody Mid 2009 Display Replacement
Use this one if you're just replacing the glass: MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement
MacBook Pro 15" Unibody Mid 2009 Display 이미지
안내서
난이도:
운영
30 minutes - 1 hour
MacBook Pro 15" Unibody Mid 2009 Front Display Glass 이미지
안내서
난이도:
매우 어려움
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you for your quick reply! I thought that was all I needed but now I see that this part number is for the part holding the glass of the screen...
I actually need to know if there is any difference when replacing the part of the unibody that has the keyboard.
my macbook hit the floor and the corner is banged in badly, making it impossible to close flush.
I didn't see why the antiglare screen should have anything to do with replacing this part, but in the instructions for replacing this part it specifically mentions that it is not for antiglare screen equipped models.
Thanks again!
Please give me a link to the guide you are referencing.
댓글 달기
귀하의 답변을 추가하세요
annabelledawido 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 619
