Drain Pump Stopped working, Replaced, worked for one load, broke
It seemed like a clear-cut issue, that the machine was not draining, and hose was not clogged. I purchased a new drain pump motor and replaced it. It worked fine for one load of laundry and now has the same issue: the washer doesn’t drain and stops before the rinse cycle.
Would greatly appreciate any advice.
좋은 질문 입니까?
점수
0
Additionally, I couldn't get the drain pump very secure with the bolts, so it's a bit loose (the motor is tightly screwed to the drain pump). The hoses were still connected when it broke the second time though.
Reece 의
Could be an intermittent timer (electronic logic board) rather than the pump itself. Not a good idea to leave the pump loose either; find out why it's not securely tightening up or you could find yourself in deeper problems.
prop man 의
OK thanks! Appreciate the advice.
Reece 의
