주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
111 질문 전체 보기
iMac 24" 2.8 EMC 2211 doesn't power on
Hey guys,
A year ago I bought a second hand iMac 24 inch, 2.8 320 GB SD iMac. Worked fine for a year. Last couple of days it was in sleeping mode. Today it doen’t boot anymore.
No fan, no sound.
When pressing the power button there is no fan speed. I red all the topics on here, and some on google, and this is what I tried already:
Switching multiple power cords and outlets.
Pressing the button for 1-2 minutes.
Removing RAM
So I decided to open her up to look if the indicator leds give any more info. They are all off.
First thing I was thinking about is try to change the power supply, but I found out that is about 150/190 dollar. Half the price of what I payed for the whole Mac.
Anything I can try ?
Update (09/05/2019)
Ordered a new power supply and it works again :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Happy it all worked out!
댓글 달기
답변 2개
선택된 답변
You might be able to fix your power supply. Your Power Supply is facing a common issue Capacitor Plague Otherwise, it’s time for a new power supply.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
How do i find out if the capacitors are safe to handle after unplugging ?
Leave the system off for the night and with the AC cord disconnected press and hold the power button for a good few minutes.
Thanks ! And by the wiki page you send i pressume i look for visual damage on the capacitors like rust, burst and leaks ?
Take a good read it will make it clear what caused the issue and yes any visible damage to the caps or leakage is the sign you need to replace them.
댓글 달기
가장 유용한 답변
Hi Patrick !
In view of the tests you have already done, it is indeed very likely that it is the power supply.
Maybe you can get a second-hand or collect it on an iMac for spare parts.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
patrick_visser 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 84
