주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Asus Republic of Gamers laptops.
352 질문 전체 보기
My Asus laptop won’t power on/boot up at all after shutting it down
My Asus Rog GL552VW laptop wont turn on after shutting it down. Right now, my laptop can still charge since the battery light turns on when I plug it in. Although, when I try to push the power button or hold for 30+ secs it won’t turn on.
This started at Aug 16 around 2am when I was running after effects in my laptop. I noticed how it was running laggy so I tried shutting it down to make it run smoother. After shutting it down I left it off for the rest of the night. The next day (Aug 17 around 10pm) I tried starting my laptop and it won’t turn on at all but is still charging.
Things I have tried that did not work:
1) Held the power button for 30+ secs while charging
2) Took off charging and waited about 30mins, then I tried to turn it on once and tried holding the button again
3) Took off the battery pack at the bottom, held the power button for 30secs, placed the battery pack back and tried turning it on again
4) Took off the battery pack at the bottom then held the power button for 30secs, plugged the laptop to charger without the battery pack and tried turning it on
5) Cleaned the dust in charging hole and battery pack area (basically cleaned my laptop)
At this point, I’ve seen people write that they just left it alone for 3-4 days and it worked again. So I’m probably gonna wait until I get an answer here
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 33개
Might be a label on the unit's bottom showing model number etc. Knowing exactly which model it is will help others help you.
Thank you, I actually know what it is now, Asus rog GL552VW
i had the same problem and i couldn’t to fix that yet.
I have the same problem with my Asus gl753ve. I send it for repair they say the battery was broken. Got it back and it worked fine the first days. Now its dead again
Hi @tunguz ,
Did they give a guarantee on the repair?
Most reputable repair services give at least 30 days guarantee on their repairs.
Contact the repair service and tell them that the problem has not been fixed.
댓글 28개 더보기
댓글 달기
답변 8개
선택된 답변
Hi @ericz1025 ,
@acervasio was talking about the CMOS battery not the main battery.
Here’s a link to a video that shows how to dis-assemble the laptop.
Here’s an image taken from the video that shows where the CMOS battery is and what it looks like.
After dis-assembling the laptop to a point where you can get to the CMOS battery (ensure that the main battery is also disconnected), disconnect the CMOS battery from the motherboard and then press and hold the Power button for 30 seconds to ensure that all residual power is drained from the motherboard and that the BIOS will be reset to its’ default settings.
Reconnect the CMOS battery and then re-assemble the laptop and check if the laptop now turns on.
(click on image to enlarge for better viewing)
If it still won’t start after this you may have a motherboard problem
해당 답변은 도움이 되었습니까?
점수 7
댓글 6개:
Thank you very much. Problem started half a year ago, with needing to hold power button for couple of minutes, or pressing other buttons with it to turn on computer. Today it just fell asleep and wasn't responding when I came back.
Your advice solved all this, thanks again (y)
Hi @jayeff
I have the same problem with my Asus gl552vw but my problem is that I have a damaged chipset in the motherboard.
I want to know how can I buy a replacement for the chipset because they don't sell it in my country
@Bashar A. Sultan
If you can find the chipset component make and type identification information printed on the chipset, you may be able to buy the component BUT it will also need to be programmed to suit the motherboard and I don't know where you would get the full programme. The chipset driver software that is provided on the manufacturer's laptop support page is not the complete program and it most probably is not even for the chipset itself but is for the BIOS chip and it tells it how to interact with the chipset etc.
You may be out of luck unless you can source a damaged GL552VW laptop or motherboard and swap the actual chip over.
Hi @jayeff
Thank you very much
Hi my ASUS ROG won’t turn on after I charge it and for some reason every time I charge it the airplane mode light comes on and I can’t turn it off. Do you know why?
댓글 1개 더보기
댓글 달기
Hi @ultra_violet
It could be that the CMOS battery is failing and that the BIOS is being corrupted preventing a normal start. When the main battery is flat the BIOS may reset back to its’ default settings as there is no longer any power on the motherboard and this allows for a normal start the next time but then maybe not after that.
I would check the CMOS battery first to make sure that it is OK. It is a non rechargeable Lithium coin cell battery that should last from 4-5 years but maybe not. Usually it is a CR2032 type battery (the type number is printed on the battery) which should measure 3.0V DC. If it measures <2.6V DC replace it. It is a common battery, available most everywhere.
Unfortunately, you have to remove the motherboard from the laptop to access the CMOS battery.
Here’s a video that shows how to disassemble the laptop to remove the motherboard.
Here’s an image taken from the video that shows where the CMOS battery is located on the underside of the motherboard. When removing the battery take note of the orientation of the battery for when you go to reinsert it back again. Usually is is +ve on top (this is marked on the battery)
(click on image to enlarge for better viewing).
When starting the laptop the first time again after both the CMOS and main batteries have been removed/replaced etc there may be a message regarding incorrect date and time. This is normal as the BIOS has defaulted back to its’ factory default settings. Once the date and time have been corrected the message will not show again when starting.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
I was playing Apex legend on a 5 year old ROG GL552VW. GPU was over clocked with afterburner and after long gaming session windows crashed and restarted. but it got stuck on asus logo. I had this logo freezing issue with this laptop before. 40sec power button press without power connection and without battery worked for me those time. but this time noting was happening. I opened my laptop and unplugged CMOS battery and plugged again waiting 20 minutes. after assembling when I press the power button the display remain black but fan running, power indicator also lights up.
As it is a 5 year old laptop I think the CMOS battery is dead. I just ordered a cr1220w battery on ebay. Hopefully CMOS battery replacement will fix the issue.
My asus rog strix g513r won't turn on
yesterday before I sleep was working will and nothing was wrong or any lagging happened but today in the morning won't turn on..... What the matter with it
@Yhia Sabbagh
Does the laptop indicate that the battery is charging when you connect the charger to the laptop?
댓글 달기
This may be a long shot but I would try removing the cmos battery and letting the laptop sit for ~30 seconds, then put it back in. If that doesn’t work, try re-seating ram sticks one by one to see if one is at fault.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I Did the “removing the battery” one and it’s still won’t turn on at all
댓글 달기
I had the identical issue with my ASUS X202E laptop. To speed the full shutdown, hold the off button down for about 40 seconds while disconnected from power. Next, cool the machine! I put mine outside on the deck for half an hour in a Vancouver December afternoon. Then, restart and immediately go to power management in settings and select the Microsoft Windows 10 recommendation for “Balanced” not the ASUS power settings. Since doing this, I have had no further issues.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi, I encounter the same issue with a GL552VW I bought used. It suddenly shut down. I could start it up again. In BIOS, it was back in 01/01/2016 00:00 but it shut down before I could access Windows 10. Did the CMOS battery replacement solved the issue ?
댓글 달기
Hello, same issue with a V752, tried everything mentioned here, no results.
I pulled out the RAM, one by one and I found that one is dead! Problem solved, now the Rog is back to life.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hiiiiii????
Asus rog gl502vy power indicator on but laptop doesn’t boot…I’ve tried all of the above but to no avail⚰️
댓글 달기
Hi its the same for me but I've had to take my screen fully off was hoping to use it with my TV but won't power on atall did at first after removing the screen full but no life atall would it be wirk taking the the shop ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You might be dealing with some serious problem or your laptop there might be some issues like AC adapter and power cord are not working properly. Try the fixes like:
·        Check your Laptop Charging
·        Check the Laptop Battery if it is removable then first remove it and then insert it into your laptop battery
·        Check for the Hardware Issues
·        If doing this won’t work for you then perform a hard reboot.
To follow the steps to hard reboot your Asus laptop read the guide on ***how to fix ASUS Laptop Won’t Turn ON***
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric Zhao 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 93
7일 전: 629
30일 전: 2,483
전체 시간: 142,050
