주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
Home button doesn't work and doesn't charge when connected?
OK a few weeks ago I dropped my iPhone. At first it worked fine however, later on the home button stopped functioning and there was no more sound when recieving a call, message or playing music through the speakers. The sound works when I have the earphones plugged in however. Also when I hook it up to charge wheather it be on my laptop or with the charger nothing happens. And now it's run out of batteries. Apart that everything else worked before it ran out of batteries. I believe that it's just a dock replacement that I need however could there be something else?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
the iphone doesn't have any other battery/power. if your connection is damaged or loose there is no way of getting power to your battery...so in this case pressing the power button on a dead battery will not get a response. When you open the iphone to check your connector I would also test the output on your battery. If it is less than 2.6 it may be too dead to recharge, buy a new battery then you know that is good for a few more years yet.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
The flex cable #4 simply has come loose. Carefully open iPhone and reconnect the Dock Port Flex Cable #4.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
OK thanks I will try that. However one more thing. Is it normal that even though it's ran out of batteries that when I press the power button I don't even get the sign or a response ? Could there be another problem there ?
댓글 달기
답변을 추가하세요
Chris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 2,241
