주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Model M8541 / 5 or 10 GB hard drive / scroll wheel physically turns
33 질문 전체 보기
no iTunes mount
My iPod 1st generation still runs, still charges, still . . . lives. It will mount as a Device on iTunes, however.
Performed all the reset routines, the internal diagnostics, tried different machines and cables. Examined and cleaned the pins.
Any ideas? Taking it apart to look for bad solder right now.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
You said "It will mount as a device..." - did you mean to say it will NOT mount? And presumably you are using a Firewire cable, correct?
Yep, my typo. Will not mount via Firewire on any computer. Tried straight 400 and 400-800 cables.
It does charge, it does play.
I disassembled it. The solder joints on the logic board look OK at the FW port.
의견 추가하세요
답변 2개
가장 유용한 답변
Does the iPod show up in Disk Utility? Sometimes a disk that won't mount will show up in Disk Utility and can be mounted from there. (You could also run disk repairs on it there, which might clear up the problem.)
해당 답변은 도움이 되었습니까?
점수 1
댓글:
DiskWarrior and Disk Util won't mount the bugger. Thanks, Mr 790.
의견 추가하세요
maybe try erasing/reformatting the drive on disk utility and then try to connect and restore on itunes.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
swiftdavid 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,342
