My Right side USB port is not working.
The right side usb port on my macbook pro isn’t working , not even a thumb drive is recognised , the left one though works fine.
please help what can be the reason and possible parts that can be faulty.
좋은 질문 입니까?
댓글 2개
Good idea to check for debris in the socket and clean the contacts with applicable contact cleaner or 90% or higher concentration isopropyl alcohol. If you open up the unit, check the USB connector for cold/cracked solder joints, loose terminals between the circuit board and the connector (if possible) and any looseness of the connector itself.
prop man 의
@propman Thank you for the fix , I did have to replace the io board.
Jil Patel 의
