Why MacBook Air Wont Charge Or Turn On?
This macbook air 13 will not charge or turn on after water damage i checked the logic board and replaced i/o board thinking the charging port was corroded. The light when i plug it in with the charger does not turn on. The charger works because i use it for my macbook. Any suggestions on what i should do or check. Before spending more money on some other part that i may not need.
좋은 질문 입니까?
댓글 1개
You might want to take a read of (or do a search here for similar information) the following:
Electronics Water Damage
FWIW, isopropyl alcohol is relatively cheap and should be readily available at your local drugstore(s)
prop man 의
