주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
Why when I pour water in my radiator it comes out of the oil drain plu
Just bought a 03 Murano took off the plastic that covers the radiator and found the radiator cap it was low on antifreeze I started filling it up and it was leaking on the right side of the engine I continued to fill with water to find the leak is think it's the oil cooler line easy to fix…. But now my oil has 2 gallons of water in the oil pan …pulled the plug and drained it out …now as fast as I put the water in it comes out of the oil drain plug…. please help thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 2개
Yes I have the same problem on my car.
Did anyone find a fix to this problem, I have an 07 Chrysler 300 3.5L Touring edition with the same issue. I changed head Gaskets 2 time and both times the coolant and oil mixed. I drained the third time and refilled the coolant reservoir to find out that the coolant was passing right through to the drain plug wtf...hoping someone has a solution km all out of ideas.
댓글 달기
답변 5개
선택된 해법
When this condition occurs the most likely cause it a blown head gasket. On V6 and V8 engine's the intake manifold gasket can leak allowing coolant down into the engine's crankcase and mix with the engine oil. To check for this failure the intake manifold will need to be removed and the gaskets inspected.
Driving in this condition is strictly verboten!
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Do NOT drive it until the issue has been resolved. It will cause catastrophic engine damage.
If the vehicle ran fine prior to this, I would not lean towards a head gasket. If the water runs straight through the cooling system and into the oil pan like that, it has to have a severe internal leak and just topping off the antifreeze shouldn’t cause the leak to increase.
I believe it is most likely a failed water pump or water pump seal as these engines have an internal water pump driven by the timing chain. If the water pump shaft or seal fails, water will enter the crank case and mix directly with the oil. The shafts fail often with this design which I believe is due to the direct force and power delivered through the timing chain. My guess is you happened to catch this at a critical time.
It very well could be a blown head gasket, allowing a water jacket to cross over into an oil port or return. Some vehicles have radiators that serve a dual purpose of cooling oil or transmission fluid as well. They have been known to fail internally allowing the water to mix directly with the oil. But I don’t think your vehicle is equipped with such a radiator. It should cool the antifreeze only. The last item that comes to mind is the timing cover may have seals that need replaced as well if it has ports for antifreeze. As for the water leaking on the outside of the engine, this is likely a separate issue. Try your best to trace it to the source of the leak or ask someone for a hand, pouring water in while the other watches and traces back to the source of the leak.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
stevelittlehope  “is think it's the oil cooler line easy to fix “ tell us more about this. It would have to be a pretty darn big leak in the head gasket to allow that much water to come out of the oil plug this fast. From what it sounds like you are actually filling water right into the pan. Could be an issue with your oil cooler line. We need to see more and need to get a better description about what is going on, from you. Post some good pictures of the top side of your engine/coolant lines as well as the bottom. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hi stevelittlehope,
In regards to your "... I started filling it up and it was leaking on the right side of the engine...." according to the service manual- engine cooling system for your vehicle there is a coolant drain plug on both the left hand and right hand side of the cylinder block as well as on the front below the water pump cover.
Did you check if the right hand side plug is OK? Go to p. CO-09 to view the locations of the plugs.
Also on p. CO-07 it has a schematic of the cooling system and if you are getting that amount of water into the oil system there may be a problem with the oil cooler itself.
I have a 99 Chevy Silverado pickup and I'm having the same problem what would be the issue for that vehicle
댓글 달기
I've got a 1997 F150 4.2L …
I tried pouring coolant in my radiator and don't know why but left the oil plug out... and this is how I found the plug wasn't in... all the coolant went straight thru the motor into the crank case and into the floor 1st then i started catching it in the bucket... could be head gasket or manifold or timing chain cover.... or freeze plugs either way more &&^&^$^ work or an new motor....
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Would this essentially be the same issue on a base line 03 mustang??
Which of the things that you mentioned did it end up being
댓글 달기
Change the oil coller and see what going on
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I have 02 Ford 150. It was running perfect but I had to put it up for 3.5yrs . Once I got back truck didn't start so put new fuel pump it started rite up so I kill it add water in tank that connects to radiator bc it has no cap on radiator but anyways I put in tank and the water was disappearing fast it took lots of water bf it was full. I checked my oil and all water I was putting in tank went straight in my oil pan fast. Oil look like milkshake but more was straight clear water at first. Please help explain why water went straight in oil pan truck wasn't even running
Truck has no crack head and don't run hott it's not nothing serious bc when I parked it. It was running perfect but like I said pour in tank that connects to radiator it goes straight in oil pan fast as if I put directly in oil pan. Need awnser what can be causing this?
댓글 달기
답변을 추가하세요
stevelittlehope 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 103
전체 시간: 20,403
