Refrigerator making flickering noise?
Hi,
I have recently started noticing flickering noise from my refrigerator. It's a 2 door refrigerator , GE 24.9 Cu. Ft. Capacity Side-By-Side Refrigerator with Dispenser.
Now the cooling in the refrigerator and regular compartment seems to be fine. I tried restarting the fridge from MCB and it is still making noise.
Opened the back panel and realized it is coming from the circuit area. Wearing rubber gloves I touched a point or two and could feel the vibration and was able to narrow down the source of sound in that area. But am clueless from there.
Here is a pic of back panel along with noise.
좋은 질문 입니까?
댓글 1개
If it's coming from the left hand side along where the yellow topped transformer is located, be very careful while exploring that area as that looks like it's the switching power supply circuitry which can give one a very nasty jolt or two even when the unit is unplugged (supply filter capacitors still retain high voltage on them. Safety practices require them to be discharge before hands on handling)
Probably, unless it's a mechanical problem due to say loose screws/bolts etc, and as you say you are clueless about working on such circuitry, probably the best recommendation is to seek professional repair services.
prop man 의
