주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Did I just fry my motherboard?
I had a water damaged iPhone 7 Plus, I took the original screen out, charger port, battery and everything else. I replaced it with all new stuff and it was working just fine. Then I tested the old screen on it and it powered up for just a second before shutting down. Now it gets really hot and won’t turn on at all. What happened?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Toasted! You have to clean the board with 99% alcohol in some cases the components are corroded /rusted and damaged that was your mistake you didn’t clean the board and inspected. If you backed everything tru icloud get a new phone if you havent try sending it to a data recovery expert.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hunter Wilcox 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 47
