주요 콘텐츠로 건너뛰기
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133 질문 전체 보기
My zte keeps getting real hot in back till almost burns hand
My zte keeps getting real hot from back of phone so hot scares me
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Might want to pop the back off and do a visual inspection (pay particular attention to any swelling of the battery). You could also do a bit of touching on the components to try and identify what exactly is heating up. If the battery shows any signs of swelling you will need to get it replaced immediately for safety's sake. See the following on how to remove the back of your phone:
ZTE ZMax Pro Back Panel Assembly Replacement
댓글 달기
답변 2개
선택된 해법
bigmama50ers  the very first thing is to remove the battery. Replace the battery with a new one and discard of the old one properly. Remember that heat always equals short circuit. Since it is at the back of the phone you most likely have a failed overcharging circuit in your battery which is an immediate fire hazard.
ZTE ZMax Pro Battery Replacement
Place the old battery in a tin can and leave it outside for a few days. There is nothing going to happen since it will be disconnected. After that you can dispose of it according to your state/community guidelines.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Another reason could be that the CPU being pushed to it's limit could be the reason because I tend to notice the heat whenever I play a game on my ZMax Pro and it does literally turn into a hand warmer even if the charger is unplugged. And in this case, the heat can also be felt on the top of the screen.
PCs and laptops have big enough heatsinks and often with a fan, most phones don't have much in the way of cooling and that's why they get hot in the hands too
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bigmama50ers 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 352
