주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
The Nokia 6 became globally available, along with the new Nokia 6 Arte Black Flipkart, Amazon, and Snapdeal special edition models in January 2017. The Nokia 6 includes model numbers TA-1021, TA-1033, TA-1000, TA-1003, TA-1025, and TA-1039.
21 질문 전체 보기
Repair faulty 35mm audio jack
Hi,
The audio jack on my Nokia 6 stopped functioning. At first it would connect intermittently , then you needed to position the jack in a particular way to get stereo sound and now it’s outright not working or connecting when you plug in the jack.
Any ideas on fixing this issue?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
I assume you’ve tried different headphones? It definitely sounds like a loose connection. You can try cleaning the port out with compressed air and a tooth pick with some rubbing alcohol(dipped on the tooth pick)
if it’s not due to dust,it’s probably a bad port. It would require a replacement. This means disassembling the phone. Sometimes it is soldered on the board,other times it is a separate part that plugs into the board.
You can also get Bluetooth earbuds if the above is too much of a hassle.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I had this problem on a Nokia 6.1. I found the plug was not pushing in all the way. After a careful look I realised the jack socket was a closed space and sand or dirt had somehow accumulated in it, stopping the plug entering properly. After switching the phone off for electrical safety I gently scraped around the bottom of the socket with a fine pin, loosening debris which then shook out when it was turned upside down. Powered back on and all had returned to normal.
This may not be the answer for you but it is quick and easy and a simple fix if it works.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
David Moseti Masese 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 77
