주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
434 질문 전체 보기
Super sensitive home button after digitizer change.
So I just did an digitizer change on an iPad mini 2 and now I have a super-sensitive home button. Any one knows why? I just have to lay my finger on it an it will react. Double tapping it will bring up Siri. Also putting some pressure on the right side of the home button on the glass will give the same reaction as to using the home button. Some problem with grounding points?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
가장 유용한 답변
Use the home button that on previous touch,The new one with touch not working well i also faced that issues before.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Did you reuse the old home button?
The new digitizer May have a slightly uneven or differently sized hole or button. It could have uneven pressure on it.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Could also be due to not having yellow kapton tape behind the screen at the bottom digitizer touch screen borders and the home button cable.
https://images-na.ssl-images-amazon.com/...
Screen had kapton, although no protection for the home flexcable. Put some plastic over it and the issue dissapeared.
의견 추가하세요
귀하의 답변을 추가하십시오
patrick 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 24
