주요 콘텐츠로 건너뛰기
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
319 질문 전체 보기
New power supply, still won't start up!
I recently had my ps4 pro die randomly while playing and it did not start up, no lights fans sounds anything.
I purchased a new PSU and it still will not turn on at all. Which leads me to believe there's another culprit. What could it be? Motherboard? APU? HDD?
There was no power surge or anything. It simply died while I was playing, so I restarted it and it died during the checking HDD screen and did not start back up. Help?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Until you confirm that the new power supply is indeed working correctly (that is supplying the correct voltage, has good connector etc) speculating about other components is pointless. Multimeter or another working compatible Playstation can be utilized to validate functionality of the new supply.
How do I check it though? I get 5v on the 4 pin connector, but how do I check 12v?
댓글 달기
답변 1개
가장 유용한 답변
Check your power supply output with a volt meter. If the power supply works properly and the output voltage fits to your unit requirement, then your unit may have problem. Just send it to the service center of that unit.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
LolSheeps 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 31
