Can not open without touching the test point?
Hello,
My Mi5 device suddenly turned off. It does not open without touching the test point as in the video below. Can you help?
좋은 질문 입니까?
Hello,
좋은 질문 입니까?
Geliştir ix Those are TP 1204 and TP1205. It forces a USB boot when bridged. So every time you plug it in it will boot while bridged. Your issue may be related to something totally different than the forced USB boot. You have tried hard reset etc., what else have you tried? Considered a new battery?
Lots of stuff going on in that video :>) Anyhow are you referring to the temporary bridging of the component shows at ~4:36 in this video? If so do us a favor and post a couple of good pictures of both sides of your phones motherboard. Maybe we can identify issues with components and the circuitry to better assist you. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
Türkçe biliyorsunuz sanırım. Translate ile çevirdim ondan anlamlar kaydı. Telefon aniden kapandı. Batarya bitti sandım batarya değiştirdim yine açılmadı. Sonra internette bu sorunu yaşayan bir sürü kişi olduğunu gördüm. Onlar videodaki yöntemle telefonu açtıklarını söylediler denedim bende de açılıyor fakat kapattığımda yine aynı şekilde açmak zorunda kalıyorum.
Google translation for above comment:
I think you speak Turkish. I translate it with Translate and record its meanings. The phone suddenly turned off. I thought the battery ran out. Then I saw on the internet that there were a lot of people who had this problem. They said that they opened the phone with the method in the video I tried to open it, but when I close it again I have to open the same way.
Geliştir ix sorry but I do not. The Turkey reference is made to the bird not the country.
It appears that there is a possibility that it is the software that bricks your phone. Have you tried to upgrade your software or tried a hard reset once you get it started through the TP bridging?
If you have a Xiaomi phone and have not yet had the opportunity to open it up and test the touch point, here is a guide on how to do so. First of all, find the lock switch on your phone. It is usually located near the bottom left corner. Once you have found the lock switch, press and hold down both buttons at the same time until the phone powers off. Next, use a pin to pry up the screen.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 204
댓글 1개
Geliştir ix lots of stuff going on in that video :>) Anyhow are you referring to the temporary bridging of the component shows at ~4:36 in this video? If so do us a favor and post a couple of good pictures of your phones motherboard. Maybe we can identify it and the circuitry to better assist you. 기존 질문에 이미지 추가하기
oldturkey03 의
