주요 콘텐츠로 건너뛰기
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 질문 전체 보기
My calculator battery life indicator isn't draining
My ti-84 ce plus has been glitching up lately, first it was abad battery, but now it has the same symptom still, i think something may have corrupted, the battery life indicator in the top right corner won’t drain
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Just to clarify, your calculator just dies due to a low battery even though the battery icon still shows full charge? I can't really tell from your question, have you tried using a new battery?
댓글 달기
답변 1개
It sounds like the battery is on it’s last legs. The TI-84 series is the high school calculator, and as such many of them end up neglected and sold at a discount to anyone willing to deal with the issues they have since acquired. This is a particularly known issue on used ones. I would change the battery out and rule out that issue since it’s so cheap.
TI sells the battery and charger here. If you just need the battery, this is the battery you want. The part number is 3.7L1200SPA
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brayden S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 18
전체 시간: 984
