주요 콘텐츠로 건너뛰기
Repair guides and support for desktop PCs manufactured by Lenovo.
75 질문 전체 보기
Power Switch not working No damage to PSU or Motherboard
I have a lenovo M90P small form factor And the power switch is not working I've tried reseating and then seeding the wires have tried the paper clip test I've used the paper clip test make sure that power runs through or everything on the motherboard and I got power to everything but the computer refuses to turn on with the power switch I've even gotten a remote power switch to test see if it wasn't the case is power switch and there was no luck there, any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
2 댓글
How did you test your PSU?
I use the paper clip test to make sure that I'm getting power through it and that gets getting power through the cord, it passed on both of them
댓글 달기
답변 1개
가장 유용한 답변
Just to be sure that everything is correctly connected, you need to check this list, but before starting you should take a photo of the front panel connector then remove everything from the motherboard (you can keep the CPU).
In the image below I highlighted the two connectors that need to be connected with the PSU and another one with the front panel connector:
According to this manual which you can find more information about your PC, it didn’t mention the front panel pins labels, so assuming by default they use the same design as other MoBo you can compare this image with the one you took.
The last thing to check if nothing works are the jumpers, I didn’t read the whole manual yet but could you please send us an HD photo of your Mobo.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Xavier Lutz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 47
전체 시간: 2,733
