주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
3022 질문 전체 보기
Part of screen not working, same with lock button! Help!
My lock button hasn’t worked for a while but randomly the left lower part of the screen stopped responding to touch. I can’t unlock my phone because of my passcode and I can’t reset my phone either because assistive touch is located where the screen doesn’t work! What can I do?!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 1개
가장 유용한 답변
I think you need a new screen. The repair guide lists the job as Difficult and there’s a lot of disassembly to do, but don’t be put off. So long as you’re well organised, make sure you note which particular screws came out in which steps so you can put them back correctly, and you have a fair bit of patience, it isn’t that hard. You just have to be very careful feeding the LCD and touchscreen cables through a slot in the midframe as there is a weak point on the inside of a bend in the ribbon where they can very easily tear. Having removed the old screen, practice reinstalling and removing it until you’ve mastered it before risking the new screen.
Or, you can take it into a shop - at that age the screen won’t be too expensive and it’ll be a fairly standard job for an experienced repair technician.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Mare lynch 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 10
