주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2010 / 3.2 GHz Core i3 또는 2.8 & 3.6 GHz Core i5 또는 2.93 GHz Core i7, ID iMac11,3
319 질문 전체 보기
LCD Controller swap from LM270WQ1 SD E3 toLM270WQ1 SD E2
I have a screen that needs replacing so purchased a replacement screen but, discovered the controller board connections are different. However can I swap my controller from the LM270WQ1 SD E3 with the controller in the working lcd LM270WQ1 SD A2
thanks everyone in advanced
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
Are you sure the T-CON board is good? Do you have a cracked LCD screen or is there another issue? You may find the problem was within the T-CON board not the LCD so you aren’t really fixing things.
I’ve never tried swapping the boards between different series so I’m not sure if it will even work. Have you tried talking to the seller of the wrong display or have any way of getting the correct one? I would hate to see you take such a risk when we just don’t know enough.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Hi Dan thanks for replying,
The original LCD has a cracked screen (long story) I have tried to contact the seller but have had no reply.
I know, well have found that the controller board can be swapped on other model screens, just wondered if the boards are changeable. The screen is identical in every way apart from the connectors on the board?
Thank you tho for taking your time to reply
Mentes :)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
mentes mehmet 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 22
전체 시간: 22
