Heat issues when running CineBench or AHT - Why and how to fix
Let me tell you my problem, I personally use the late 2011 13 inch mbp and have replaced hdd to ssd, 16 gigs of 1600 mhz ram and applied arctic mx4 freshly. Now I find little improvement in cooling and very good improvement in performance due to the huge upgrade. But however when I use cinebench or other cpu hungry process, the CPU hits 98-100 celsius with fans going beserk. But when it's idle, the CPU sits at 45-49 celsius. I can understand this could be accessing the SSD through the faulty cable. but even when I go to the Apple hardware test, the fans still scream during memory test.
So, is it really the SATA cable end of the day as mentioned elsewhere that is causing this problem?
TGPro screen when idle
TG Pro when medium task
TG Pro when memory usage is high after many hours of work on project file
TG Pro at full load and fans screaming
좋은 질문 입니까?
댓글 2개
I spun your question out as it really needs to be looked at independently from where you had it.
Dan 의
Ah cool. I was wondering where it went. Thanks.
Vijay Kanta 의
