booting to apple logo
Hi. Replaced the screen on my iPhone 8 plus. Everything went well. The phone booted up fine initially however after a while it stopped booting. Now I simply see the apple logo and then it shuts off
Help please
좋은 질문 입니까?
Help please
좋은 질문 입니까?
Plug your iPhone with your PC, run iTunes, make a backup file then restore it to factory settings.
If you haven’t upgrade your phone to iOS 13 then iTunes will probably do it while restoring.
해당 답변은 도움이 되었습니까?
First remove the home button flex and check.Most of the cases home button also cause that issues.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 47
It could be a lot of things but being an 8 I would pop the screen open, remove the connectors shield and put pressure on the battery connector and see if it boots up.
Chris Stables 의
I removed the display and attempted to reboot the phone and it appears to be working fine. Carefully replaced the cover and seems to be ok
Thanks
Raymond Martinez 의
