주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
iPhone 7 touch screen not responding intermittently and slow boot
Hi all,
My iPhone 7 is behaving very weirdly after being dropped face-down last week.
History
  • I dropped it (in a Speck Candyshell case) a LOT - sometimes multiple times a day. I’m clumsy; the Speck is great.
  • Dropped it face down onto concrete and the screen smashed under the hard screen protector.
  • After the drop, the left side of the screen seemed to be intermittent - assumed touchscreen damage
  • I tried rebooting it and it sat on the Apple logo for a LONG time - maybe 5-10 mins
  • I took it for a third party screen replacement today (apparently refurbished Apple official screen), but the behaviour problems persist.
Current State
However, now the screen is replaced, the weirdness persists:
  • Somewhere between 5 and 120 seconds after waking the phone with the Home button, the screen will not respond to touch input. I can press, swipe… nothing. The app on-screen still runs normally, WiFi access icon swirls, cursor flashes, etc. But I can’t do anything.
    • If I leave it long enough (30-120s?), then it will start responding again
Some further testing shows the bounds of this behaviour:
  • While hung, apps continue running on the screen fine
  • There are no unusual visual indicators on the screen at all
  • There’s no apparent physical pressure, orientation, etc. where the touchscreen will hang
  • Also no particular app that’s running, system load, etc. that triggers it.
  • While hung, pressing the Home button shows no response
  • While hung, pressing the Sleep/Wake button does sleep the screen
  • If I press the sleep/wake button, then wake it again with that or the Home Button, then the screen is immediately responsive again:
    • I can log in using a PIN code and it responds fine, or log in using TouchID
    • I can open the last app and continue working on it
    • I can open other apps, swipe around Springboard, swipe up for control centre, down for Notification centre, etc.
  • However, after the 5-120s, the screen hangs again, and again I have to sleep/wake it. And then again, it’s immediately responsive again.
I of course would assume it’s due to some physical damage on the phone logic board. I’m aware of the blurring of hardware and software on the iPhone, but this is really weird. I’m struggling with why, if it’s a hardware issue, I can kick it with a sleep/wake cycle and it acts as if nothing had happened.
There is also other weirdness that would imply hardware issues.
  • Also, again, if I soft-reset the phone, the Apple logo will stay onscreen for a LONG time - 3-5 minutes. Evidently it has issued.
  • Also, I’m unsure if the mic works. I can neither hear or be heard on a phone call on the handset, unless I use a bluetooth headset. I get a greyed-out speaker/headset icon on phone calls. But the speaker does work with music.
  • I also have FaceTime audio calls fail soon after I make them. The call goes through and the receiving party phone’s ring, then it stops ringing.
I’ve not tried factory-resetting yet, as that needs some time to put in motion.
I would love any feedback on what might be the issue here - whether it is software, or definitely hardware?
Many thanks
D
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi,
Firstly, this sounds like the ever common ‘Audio IC’ disease which affects the iPhone 7. A lot of the symptoms you say point to this. It is caused by flex of the board which causes a trace that goes to the Audio IC (Pad C12.) This causes the phone to take a very long time to boot and 99% of the time results in the voice memo app not functioning, but also most of the other issues you described.
This will need a Level 3 repair by someone who can micro solder to run a jumper along the affected trace to repair it. You might be able to find someone local, but there are some great mail-in services that are great at this.
You can read more about this here: https://www.discdepotdundee.co.uk/iphone...
In regards to the other issues, it could still be a faulty LCD module, but would have to try with a known-good part to verify. The audio IC fault has also been known to cause touch issues as the trace that fails is also related to the touch circuit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dan S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 219
