주요 콘텐츠로 건너뛰기
In its first year in production, the Santa Fe was offered with one of two engine and transmission combinations. In North America, a fuel-efficient 2.4 L four-cylinder engine was standard equipment and could be mated with either a 5-speed manual or a 4-speed automatic.
How much to replace a ball joint, my right side is sideways
My front right side wheel is sideways
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Replacing the entire control arm with ball joint included can be done by you and a friend in only a couple of hours, you can get all tools needed from your local parts store rental program. If you take on the job, use safety stands, you don’t need air tools but will take longer with hand tools such as a socket set, you will need wrenches also and a few other items as seen in the video.
https://www.youtube.com/watch?v=0M4UIqw_...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
tcbtommy56 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 259
