The green and orange charging light flashes back-and-forth constantly
When I’m charging the calculator the green and orange light flash back-and-forth constantly, The calculator won’t even turn on, what’s my problem?
좋은 질문 입니까?
좋은 질문 입니까?
First, I’d try charging it from a different power source (like a different power brick or use your laptop). If the problem persists, then that sounds like a bad connection with the battery or something has gone wrong with the battery. When the LED turns orange, that means it’s trying to charge the battery but when it turns green that means it’s not detecting a battery to charge.
Try taking the battery out and inspecting it for any damage and check if the three metal contacts are clean. Refer to Texas Instruments TI-84 Plus CE Battery Replacement if you need help with that. If the battery looks fine, then you might want to try a friend’s known, working battery or buy a new one to try. There’s a slight chance that pressing the reset button on the back of the calculator can force it to come back to life.
Could you please tell me how old your calculator is? Someone recently posted a similar question and I’m wondering if they’re related.
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 25
30일 전: 175
전체 시간: 10,102
My calculator does that too it’s like blinking black and green lights would it be the battery or something else that can be fixed ?
Casio fx-991ES PLUS
La Luce 의
@la luce I'm not all that familiar with Casio but a battery replacement would be the first thing I'd try.
TheLastMillennial 의
