주요 콘텐츠로 건너뛰기
모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
213 질문 전체 보기
Can you upgrade wifi card
I am wondering if it would be possible to put a more modern apple wifi card, for example from a 2017 iMac. I mainly want to do this for the Bluetooth connectivity, also would it be possible to add an SSD and lastly is 32gb ram possible on this model?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
If you have a 2012 iMac then you already have a newer version of Bluetooth 4.0 (the current iMac’s offer 4.2) that as far as I know is fully compatible with everything being produced today. The newest version is called Bluetooth 5 and it is was just ratified and still very early for products.
While WiFi (802.11n) has been upgraded a few times current version (the current iMac offers 802.11ac) it would require more than the board to gain the higher throughput of the newest standards. MIMO requires more antenna’s than what your system has. The newest standard is WiFi 6 and it was just ratified and just being introduced
If you can’t directly wire your system to a hight speed Ethernet network directly you can still leverage it to connect to an external WiFi bridge which has the higher throughput WiFi (802.11ac)
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Ok thank you, I am mostly interested in getting the iMac to work with sidecar and unlock with apple watch which is incompatible with the hardware.
의견 추가하세요
귀하의 답변을 추가하십시오
David bellows 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 95
