Repair my iMac 2134
Hello:
My Imac does not work.
I looked if it was the memory but it is ok
It Sounds some beeps and does not start
If the problem is not the graphic card, i would like to change my hard drive anyway
좋은 질문 입니까?
Hello:
좋은 질문 입니까?
Apple iMac "Core 2 Duo" 3.06 24-Inch (Early 2008) Specs
Identifiers: Early 2008 - MB398LL/A - iMac8,1 - A1225 - 2211
This is a RAM problem. Please remove both sticks. Install one stick in the upper slot and start. If all is well, remove it and put in the lower slot and start. Repeat with the other stick. This will test both the RAM and the slots. Everything may work just fine and all that was needed was to reseat. Please let us know your results. Thanks
해당 답변은 도움이 되었습니까?
You may have a bad slot. Following directions will uncover this. Wait of the hard drive till you have this problem solved.
Generally speaking, 3 beeps indicates that there are no good banks of memory. This could be due to disconnect, faulty modules, or a faulty logic board. Best case scenario is that you pull and reseat the memory, and it works fine. Next test each memory stick individually. If that doesn't work try and get your hands on a set of knowing working memory and test again. If that doesn't work, you need a new logic board.
해당 답변은 도움이 되었습니까?
EDIT: I should have been more specific, the 3 beeps mean that there is no good RAM installed currently.
I´ll try with a new bank of ram
If i have to remove the hard drive, is possible a external usb enclosure for imac hard drives?
If i remove the hard drive, what model of external firewire enclosure is compatible with this model of imac?
I´ve tried with new bank of ram and still the same beeps, i will remove the hard drive, do you know what firewire enclosure is good for this imac hard drive? or i can use any firewire enclosure
regards
You have a RAM problem, so why are you messing with the hard drive?
On all Intel Macs there is no need for a firewire external - USB works as well for booting. You can use any case that accepts a 3.5" SATA drive. Anyway, i don't understand the discussion, because if the computer has a problem with the RAM slots there is no point booting it externally. Is there something i aint getting?
해당 답변은 도움이 되었습니까?
The problem i have is not the ram, i bought a new bank of ram and tried with the two slots of the ram and still the 3 beeps fast, 3 beeps diferent and 3 beeps fast. the hard drive i want to remove to recover my data, thanks
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,524
댓글 2개
How many beeps--also what are the last three digits of your serial number?
rj713 의
I hear first the superdrive loading, then 3 fast beeps, 3 paused beeps and 3 fast beeps
The last 3 digits of my serial number is OKM
regards
Jose Carlos 의
