주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
Help! MacBook doesn't boot properly after battery swap
HELP, I swapped the battery as described by the instructions, step by step. Don't follow the guide, removing the motherboard is way to risky… I now have apparently damaged the logic-board (according to apple genius). When I try to turn on the macbook the initial loading-bar takes way longer and at about 3/4 the screen shuts off. Does anyone know where ì could look for help or what to do?
Additional information:
- if I boot to the bootcampscreen (pressing r) the display doesn't die, until I actually try to boot…
Is there a way ì can save my beloved mac? Thanks for any help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
On recover page click top left to check start up disc if it see hard drive you will need to load os Sierra on it boot to flash reload your os to fix
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Simone 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 25
