iPad is disabled connect to itunes on MacOS Catalina
Hi, I have a ipad with error message “iPad is disabled connect to itunes” but itunes is no more available on MacOS Catalina !
Can somebody please help me to restore this ipad ?
좋은 질문 입니까?
좋은 질문 입니까?
Check this out, it is still possible to restore an iDevice on Mac OS Catalina:
해당 답변은 도움이 되었습니까?
Hi, Thank you for your answers ;-)
I finally found the solution. iPad was managed by “apple configurator 2”, so I started the iPad in recovery mode and connect to “configurator 2”. Then click on “recovery”.
Best regards
해당 답변은 도움이 되었습니까?
Thank you so much! This did the trick. I downloaded the configurator and clicked around with update (I believe I had to restart the iPad once to get the process going). It installed a new operating system.
hey! did u find out?? im having the same problem rn and i don’t know what to do lol
해당 답변은 도움이 되었습니까?
This is the official article on how to fix what you’re experiencing:
해당 답변은 도움이 되었습니까?
it didn't work :(
You know what? I read an article about this exact same problem!
So here is it: iPad is disabled connect to iPad
Basically, you hook up your iPad with your mac, and you will see a notification telling you to restore the iPad.
If not, the easiest solution is to use Joyoshare iPad System Recovery to restore the iPad without data loss.
해당 답변은 도움이 되었습니까?
Resetting the ipad can be done using the Finder on Mac OS Catalina.
This video demonstrates this process.
해당 답변은 도움이 되었습니까?
if you have a separate device like windows you can use iTunes from there, or upgrade to a newer version of mac os
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 8,295
댓글 1개
No one has yet found an answer. Apple sure stuffed getting ipad back alive
Walter Poole 의
