주요 콘텐츠로 건너뛰기
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101 질문 전체 보기
iPad is disabled connect to itunes on MacOS Catalina
Hi, I have a ipad with error message “iPad is disabled connect to itunes” but itunes is no more available on MacOS Catalina !
Can somebody please help me to restore this ipad ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
No one has yet found an answer. Apple sure stuffed getting ipad back alive
댓글 달기
답변 7개
가장 유용한 답변
Check this out, it is still possible to restore an iDevice on Mac OS Catalina:
https://www.imore.com/how-sync-your-ipho...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hi, Thank you for your answers ;-)
I finally found the solution. iPad was managed by “apple configurator 2”, so I started the iPad in recovery mode and connect to “configurator 2”. Then click on “recovery”.
Best regards
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you so much! This did the trick. I downloaded the configurator and clicked around with update (I believe I had to restart the iPad once to get the process going). It installed a new operating system.
댓글 달기
hey! did u find out?? im having the same problem rn and i don’t know what to do lol
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is the official article on how to fix what you’re experiencing:
https://support.apple.com/en-us/HT204306
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
it didn't work :(
댓글 달기
You know what? I read an article about this exact same problem!
So here is it: iPad is disabled connect to iPad
Basically, you hook up your iPad with your mac, and you will see a notification telling you to restore the iPad.
If not, the easiest solution is to use Joyoshare iPad System Recovery to restore the iPad without data loss.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Resetting the ipad can be done using the Finder on Mac OS Catalina.
  1. turn off iPad and unplug from Mac
  2. start Finder
  3. press Home button
  4. plug iPad in while Home button is pressed
  5. iTunes logo will appear on the iPad
  6. iPad will appear in Finder
  7. a prompt to update or reset to factory settings will appear on the Finder.
  8. Follow on screen instructions to update or reset the iPad
This video demonstrates this process.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
if you have a separate device like windows you can use iTunes from there, or upgrade to a newer version of mac os
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Guy Lerou 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 8,292
