주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2010 / 3.2 GHz Core i3 또는 2.8 & 3.6 GHz Core i5 또는 2.93 GHz Core i7, ID iMac11,3
382 질문 전체 보기
What's the best CPU I can put in a mid 2010 27 inch iMac?
So I have an iMac 2010 27inch and have an i3 in it, even with a SSD in it it’s a bit sluggish because the CPU just isn’t good enough anymore. What’s the best upgrade I could put in there to make it better? Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The best CPU this series had was a 2.93 GHz Core i7 (I7-870) thats the best you can go.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Nothing better then? I saw some people talk about Xeons for example
Xeon's, really! There's more to it than plug and play here.
First the system's power supply needs to be powerful enough to supply the power the more powerful chips of the day needed. While newer chips have gotten better in their power needs by die shrink in the same effort the CPU sockets have been altered and the PCH logic and system firmware likewise will need to support the CPU in question. Nothing like that has happened in this series.
@danj Yeah I guess that makes sense. i7 it is then! The i3 is really choking up these days now and everything is laggy even with relatively enough ram
@nar001 - An i7 will be a very good upgrade given what you currently have an i3, it won't be sluggish afterwards ;-}
Don't forget to get your system to at least 8 GB or RAM 12 GB is what I would go for.
댓글 달기
귀하의 답변을 추가하세요
Nar001 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 30
전체 시간: 789
