주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
677 질문 전체 보기
Why is my vibration making a crazy buzzing sound?
I replaced my charging port and speaker on my phone and before this my Taptic Engine was working perfectly. I put everything back and when I turned it on it made such a loud buzzing noise I thought I broke something. Turns out it was the Taptic Engine, I looked up how to fix this issue and everybody said to tighten the screws, so I did. This did not fix the issue, so I bought a new Taptic Engine and the same problem occurred, same buzzing noise. It’s been about 3 months and I just now saw that it could be the charging port at fault due to a short or something. I have the original charging port so I will be checking my other charging port to see if the vibration works on that one but I want to know if buying a new charging port will fix the issue. Any thoughts, ideas, suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Can you record the sound? Sometimes the tone of the sound can offer a clue on what is the cause.
@danj when I get home today I’ll do that but it’s just a loud buzzing noise and when I try to put a vibration style it only vibrates once then stops.
@danj here is the link to the audio coming out of my phone https://www.youtube.com/watch?v=9Qbaxgzu...
댓글 달기
답변 1개
선택된 답변
@danj btw I had the original charging port that came with the phone so I plugged it on to the motherboard connected the spare vibration motor I got to replace the one I had and it was working like a charm, at this point I know its the charging port flex so im going to order one up soon.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Just in case anyone is interested in knowing how the repair went, I replaced the charging port and it was successful. The vibration is now fully working and doesn’t make any loud noises.
댓글 달기
귀하의 답변을 추가하세요
Yair Gomez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 72
전체 시간: 5,512
