주요 콘텐츠로 건너뛰기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
85 질문 전체 보기
iPad Air 2 wont turn on
iPad Air 2 wont turn on or charge, there is absolutely no signs of life. i measured it via lightning caple to input voltage about 5.20 volts but not any current, it says 0.00amps even after charging overnight. Tried hard resetting multible times, no luck. iTunes doesn’t recognize it at all.
I really want to see if i can fix the problem without taking it apart, since i dont want to risk cracking the expensive display/digitizer combo.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Maybe you have a bad dock charging connector??
Is the charging cable loose when it is inserted in to the dock
Has you do not want take apart the iPad ?/ bu what you are saying you will have to
The Thristar tester would give you a good idea what is faulty but not 100% full proof
Link
https://www.repairsuniverse.com/products...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
it might just be that the battery is stone dead and needs replacement. the lightning connector fits snug and perfect within the charging port without any wiggle room. i guess i will have to take it apart and start testing.
댓글 달기
귀하의 답변을 추가하세요
Tubbe Lenbroch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 66
