주요 콘텐츠로 건너뛰기
모델 A1106 / 1280x854 스크린 해상도
90 질문 전체 보기
Charger orange light, battery doesn't charge, PB doesn't turn on
Not sure how many people are around to help with an issue like this, but here it goes...
Got a PB 15" 1.5Ghz a while ago with these symptoms. I tried replacing the DC-In board and no luck, and I'm 90% sure I tried a different charger.
Now I've just noticed that it's got DDR2 533 mhz RAM when it should have DDR 333, I don't have any of this to try so I tried taking them out and booting up, it should beep at me, right? Anyway the light is still orange on the charger.
Reset PMU, taken out battery (which is a cheap knockoff), my next bet is to replace the motherboard.
Any suggestions before I do this?
Any help greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Before spending the money for a new logic board try just one stick of the correct RAM. You said you got it "with these symptoms", and listed no symptoms. You have a power supply that you don't know if it works and a knock off battery that you don't know works. RAM that you don't know works and you want to replace the logic board? You have to many variables to isolate a problem. Please tell us the symptoms before and after you replaced the DC-IN board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
spacec0w 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 12
전체 시간: 866
