Vertical bars on screen
I have the same issue on the last version of the 17inch mbp is it fixable on that version? Or same all broke needs chucking out?
좋은 질문 입니까?
좋은 질문 입니까?
Vertical lines seen on a computer screen may be a result of hardware failure, which requires a hard reset (or forced reset), or an issue with your video (graphics) card. In most cases, these lines are caused by damage to the screen lite blue
해당 답변은 도움이 되었습니까?
@david236 - True! Its likely a hardware issue. But it can be the GPU instead of the the display. We also have a few cards up our sleeve to over come some issues! But I need to get a better idea what the OP is seeing as that will give me a clue on what's needed.
OK, I see the faint vertical lines which are equally spaced (more visible in the top right in you pic) This looks like a noise issue within the internal displays LVDS connections.
Let’s do one more test to make sure. Connect your system to an external monitor do you see the lines on it as well?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 191
Please post some pics on what you are seeing 기존 질문에 이미지 추가하기
Dan 의
There are known issues on some of these models. Please identify your exact machine so we can give you correct advice. Go here and enter your serial number then tell us what you have.
https://everymac.com/ultimate-mac-lookup...
mayer 의
