주요 콘텐츠로 건너뛰기
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 질문 전체 보기
Ps Vita power Issues
So I had this ps vita from a friend, and it's really old. It works sometimes when I turn it on and sometimes it won't. Here's what happens :
  • It turns on sometimes, sometimes it won't
  • No light on the ps button and it doesn't charge, but the pc recognizes it when I connect it via cable
  • When it does turn on, it randomly turns off at some point
  • I had to set the date and time every time It powers on
  • I've tried replacing the battery, and it immediately powered on. I tried to chrage it but it still won't. I powered it off just to be sure
  • Now the problem is back again. It won't turn on, won't charge.
Anybody knows what the problem is? Could it be the port where you connect the battery to the board or anything else? I really need help right now.
Any help would be very much appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I don’t think it’s the port where the battery connects to. You can try to clean it carefully. Did you tried a new battery or a used one? When you connect it to the PC, does it charge then? And is it recognised when it’s not displaying anything? Did you checked the port where you put your charger in ?
Looks like it’s a motherboard related issue so far..
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
I tried a new battery, I brought it new and it just came in today. It doesn't charge when connected to pc, but i can transfer files. Haven't checked the charging port yet. Haven't tried clening it either. Should it try it? If so, what should I use?
Thanks fir the reply
Hi !
Can you transfer files when it's not displaying anything ? I think the port is fine, but you can check it out anyway. Does the battery connector looks fine? You could clean it carefully with plastic (thin) inside, for the battery connector, clean the pins. But I think it's motherboard related..
I can't transfer if it's not showing anything, it's as good as a dead vita at those times. There's nothing wrong with the battery connector, at least on how I look at it.
I would try that later, thanks again!
Okay. So it's not the screen or anything. I think the connectors are all good to go, but just check to be sure. Guess it's motherboard related, sorry. You can still buy the motherboards though.
I'll try if I can find a cheap one, but if I can't then I'll just buy a new one. Thanks!
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
lordcrew27 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 25
전체 시간: 1,193
