Medion Akoya won't power on.
What can I do to my Medion Akoya p2212t which charges fine, but won't turn on. When power button is pressed, it displays the power light for a maximum of milliseconds more like a blink instead of, for at least 2 seconds.
좋은 질문 입니까?
daniel isiguzo how do you know it charges your battery? What have you checked?
oldturkey03 의
@oldturkey03 it displays the charging indicator light, when a charger is plugged in. So I believe it's charging fine. Just saying tho, do you have a contrary view?
daniel isiguzo 의
Not really but those general symptoms are always tough to figure out. This could be anything from a bad power supply to bad processor and many things in between. I like to start with the power so I question the ac adapter and battery first. If you have a meter check the adapter then the battery. After that you are at the power switch and finally the motherboard. Schematics are scarce which complicates things even further.
oldturkey03 의
Okay.. Thanks for the help. I'll see what I can do.
daniel isiguzo 의
