Ink cartridge carriage will not move
After replacing an ink cartridge, the carriage moved to the right and did not return. I checked "troubleshooting" and followed the steps indicated, but the condition of the carriage did not change.
좋은 질문 입니까?
좋은 질문 입니까?
It sounds like the cartridge is binding the carriage. Unplug the unit and physically move the carriage to the center. Check that you have the proper cartridge and that it firmly installed. Plug in the unit and turn it on. Please let us know what happens.
해당 답변은 도움이 되었습니까?
Thanks, did the trick!
I tried this and it did not work on my Pixma MP980
Worked perfectly on my Pixma Pro-100 that had been sitting in storage for 2 years! Thanks!
I have a Pixma 5420 and the cartridges are stuck to the right. I cannot physically pull them over. How do you get the cartridges to move?
Still unable to manually move the carriage
I don’t know if any of you fixed your problem. But I myself had a TS8160 Canon printer where the cartridge carrier was stuck to the right position.
What I did that worked…
1st: Unplugged the printer completely.
2nd: Look at the white circular gear on the left hand-side and rotating it clockwise until I heard it click once… (checked the carriage - still wasn’t budging)… then kept rotating the gear more until I heard it click again… and then wah-lah… the “cartridge carrier” was released when I moved it to the left!
Next step is I have to clean the cartridge head. But with that… I think I have to go find a video tutorial. lol. Hope this helps someone!
해당 답변은 도움이 되었습니까?
Why is my green and yellow on my flush even though I put the ink cartridge are in and they are fill G4511 and it does not want to click in canon
I went to do this fix after 10 months of not using our printer here and Voila! I found a hair rubber band that had gotten lodged under the roller pins. YAY! now it works!
해당 답변은 도움이 되었습니까?
Did not move the carriage
can not move cartridge manually just stuck
My mx922 canon printer is stuck and I can't see even see my ink cartridge.What can I do ?
Please I have issue with my HP deskjet 1515. All the attention light is blanking when I plug it. If I try to print or test run something I will hear the cartridge carriage moving left and right without collecting any paper and if I open the cartridge carriage are it won't come to the middle.
Please am stucked ,I need immediate help.
해당 답변은 도움이 되었습니까?
I have the same issue with my HP Deskjet 2050... kindly assist...!!!
The same issue with my hp deskjet ink advantage 3835
HP 3070A said I had a paper jam but it wasn’t that at all - one of the cartridges was a fraction higher than the others, actually the blue one. Fortunately it was close enough to the left (but the whole print carriage was still to the right) that I could get my finger over it to push it down, Bingo! wasted a lot of time trying to clear paper jam!
해당 답변은 도움이 되었습니까?
this is happening to mine right now. I am trying to remove the blue cartridge but it's not budging.
update I got it fixed.. i used a marker and applied force. :-)
however since yesterday it is printing alot of double letters and lines. canon pixma mx922
can anyone advise please
It appeared my ink cartidge carriage was stuck. As recommended, I moved it physically into the middle and now it is working again. This is the first time I had a problem with the Canon printer since I purchased it over 7 years ago.
By the way, my old HP photosmart printer purchased 20 years ago is still working like a charm as well!!!!
Heidi O.
해당 답변은 도움이 되었습니까?
I loved my HPs but after buying two that quit within the first year I switched to Canon. I love the Canon for photos, but it always cuts off the bottom of every regular document I print. So sorry, that HP got so undependable.
Can't move the cartridge carrier
해당 답변은 도움이 되었습니까?
how did you move it accross
Lexmark 63 cant move ink cartridge. HELP
my hp 3700 series is new. the ink cartridges came with the new printer. the cartridge holder will not move into the space to install the cartridges. i tried gto gently move the holder but no dice still stuck
Cant move mine phisically either its stuck canon pixma mg7720
해당 답변은 도움이 되었습니까?
Mines a 9250 and can't move it either, really stuck in there, any other ideas plzzzz??
I found I couldn't move it manually, but with a little coaxing from a kitchen knife AFTER UNPLUGGING IT, it was easy.
Where did you put the kitchen knife to nudge the cartridge? the black cartridge is only partially visible from the front - it is jammed into the right side. Did you jam the knife under or between or ? Thanks
@sallypepper321 where and how did you use the kitchen knife? I tried that as well but I put it at the top of the ink and press down and that didn't work.
how did you do it I have a cannon 922
i moved my canon ip7240 but is not working
해당 답변은 도움이 되었습니까?
HP ink tank printing queue...no obstruction but still error. All the lights are blinking
Hi
I also have this problem, and although I can see what is causing it I don’t know how to fix it.
I have a Canon TS8250, and the ink cartridge carriage will not move completely to the right. The reason is that the inky pad to its right doesn’t stay down - it is about 1-2 mm proud of where it should be and so gets in the way of the carriage. Maybe one or more of the small plastic lugs it is held in by are broken, in which case is it possible to get a replacement for this part? Or is there a way to get it to stay down without getting a replacement? Also if anyone knows the proper name for this inky pad I would love to know what it is! Thank you.
해당 답변은 도움이 되었습니까?
I was eventually advised by Canon to buy a new printer as I couldn’t fix it myself and a new one was cheaper than having it fixed.
해당 답변은 도움이 되었습니까?
How about leaking cartridge what is the solution.? Or I need to replace a new one??
해당 답변은 도움이 되었습니까?
Why is my green and yellow on printer flash even though I put the ink cartridge are in they are fill G4511 and it does not want to click in my printer canon
해당 답변은 도움이 되었습니까?
24 시간 전: 87
7일 전: 558
30일 전: 2,677
전체 시간: 132,229
I have tried this and the cartridge carriage will not move physically. Please help!!
doddsarah 의
harrisonferdinand 의
My lexmark 63 carriage is stuck & empty. How to fix & put in ink cartridge ?
Elaine Solomon 의
My MG2540 carriage also got stuck. I moved it to the middle, changed the cartridge and voila, everything works. Thanks
Coen de Milander 의
I have the same issue with my pixma mg3220. While checking why this is so I tried to remove the color cartridge and while doing so a plastic lever like with spring falls off. I don't know where it came from so I don't know where to re install it. I wish somebody could help me on this.
Feliciano Balajadia 의
