주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
Why no sound except when using a usb adapter on a late 2011 A1297
There is no available sound for the internal speakers nor microphone jack.
The icon for sound when tapping the f11 or f12 keys has the slash for no sound unless the ubs adapter is plugged in.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Judging by the 2 responses, I may not have made clear the problem I have
There is no internal sound of any kind nor does the mic jack for external output sound work at all.
The usb adapter is the only way there is any sound
댓글 달기
답변 2개
가장 유용한 답변
To add a bit more to Fenando’s answer your jack has a set of switches as you can see here
So when the plug is inserted the internal speaker connection is dropped. In addition the digital output is enabled which is the source of the Red light coming from the jack.
Sometimes the contacts get out of alignment or dirty which is what I suspect you are facing here.
Update (11/03/2019)
At this point I think you’ll need to pull the logic board out to inspect it for corrosion or other liquid damage around the DAC chip which is located on the back side of the logic board (marked RealTek) MacBook Pro 17" Unibody Logic Board Replacement. You might need a new logic board.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
( 1 ) This old models have the optical audio inside of the audio jack, if is dirty will recognize a optical output. ( 2 ) If you are using a external audio adapter make sure that you are sending the audio to the right device on your settings. ( 3 ) Audio Card malfunction or Liquid Damage on the Logic Board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Dan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 65
