주요 콘텐츠로 건너뛰기
Kia Motors/기아 자동차에서 제조한 승용차 및 SUV에 대한 안내서 및 수리 정보
289 질문 전체 보기
Why arent my cooling fans woorking in my 2009 kia rio lx1.6l
how can i test my cooling fans so i know what to fix an are there fuses on this one
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
ricknickdick you are not telling us what is going on with your fan. For your Rio the no cooling fan operation is commonly caused by:
Cooling fan fuse
Fan motor
Wire Harness
Radiator Fan Relay
A/Con Relay Rad Fan Relay
Here is a diagram of the relays location in the under the hood fuse box
To test your relays, you should have continuity between terminal 1 and 2 when powered on and ground connected to terminal 3 and 4
You can check the fans by simply disconnecting the harness and applying 12V to the connector end to the fan. If the fans turn you know they work the check the engine temperature sensor like shown on here as well as on here The fan is controlled by the PCM, via a signal from the Engine Coolant Temperature Sensor (ECTS) sensor
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
ricknickdick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 759
